ONEX #54 Web Site
Date:  10-26-2013
Number of Hours:  3.00
Manual Reference:  W12
Brief Description:  Dimple right inboard skins
Dimpled the leading edges of the right inboard skin and skin doubler.
Replaced the trailing edge 1/4" plastic hose conduit with 3/8" plastic conduit. If I need to connect a roll servo to the airleron bellcrank in the outboard wing, it will require about 7 wires, so a larger tube will be helpfull.
Brushed on Stewart Systems E7520 EkoPrime to the ribs and spar areas that will contact the skins.
